Joseph
October 5, 2021, 7:26am
1
Can anyone recommend an inexpensive flip phone that's compatible on the T-Mobile network?
It's only needed for basic voice service. So any dumb-phone should suffice. It can even be a used device.
Presumably it should be 4G comparable, in order to survive the 3G network shutdown.
TIA
Alcatel 4052W or 4051S (unlocked). You can find them on eBay.
dst11
October 5, 2021, 11:26pm
3
Yes. I got a 4052 (Smartflip) and it works just fine for voice. It has internet too but I haven't bothered with that. My 4052 is locked to ATT but I've been using it on an ATT MVNO (FreeUp) without any problems at all.
The 4052W is locked to T Mobile and the 4051S is locked to Verizon. I have a 4051S but mine is unlocked.
dst11
October 7, 2021, 9:45am
5
Here's a picture of the 4052:
It's locked to ATT but I use it on FreeUp just fine. I didn't specify a letter after the number because I wasn't sure what the correct number was.
UPDATE: It's 4052R
Joseph
October 8, 2021, 3:29am
6
What is the street price for these Alcatel flip phones?
