If I port out my number do I loose my rewards if there are no active lines with Tracfone? After I port out and when the walmart gift cards become available again, I would use those to use up my remaining reward points.
They don't disappear right away but they will disappear. I think you get a month maybe before they close your rewards down and the points disappear.
I'd buy a phone if you have enough. You can probably sell it if you don't need one. Or swap it at visible.
And I don't think you can redeem points when there is no active line in the account.
I would agree. Buy a phone with points
