Tracfone: Unlocking phones
I thought I'd share my experience with getting a Tracfone-branded phone unlocked, and info that I've gleaned elsewhere.
The possibility of getting Tracfone-branded devices unlocked is pretty new, and details on what works & what doesn't are mostly through anecdotal reports, rather than a clear set of statements from Tracfone.
[i]What Tracfone officially requires:
Customers must request handset unlocking.
Customers must have had their locked device activated on TracFone service for no fewer than 12 months, redeemed air time cards in no fewer than 12 months, and not have had their telephone number recycled or ported.
Customers must request this interim unlocking solution while their service is active or within 60 days after their active service days expire. This 60-day grace period applies even if the customer's telephone number was recycled or ported.
Customers must currently own a TracFone branded handset model launched on TracFone's service after February 11, 2014 or activated with TracFone's service after February 11, 2015.[/i]
There's lots of grey area in those requirements!
My timeline: I had an active Tracfone line for a number of years, with existiingg units and service time. Just over a year ago, I transferred my service to a new phone, an LG Fiesta 2 purchased via Tracfone's Ebay store, that came bundled with a year of service and units. For grins, I had checked the phone a couple of times for unlocking during the year, and it was judged not yet unlockable, as anticipated. A few days after the one-year anniversary, I tried the unlock request again, and it went through just fine. My Fiesta 2 was a relatively uncommon (for Tracfone) T-Mobile-network device-- I've tested it with Mint Mobile and FreedomPop (AT&T data) SIMs, and both work fine, so it is truly unlocked.
My current understanding of what's really required to unlock a Tracfone, and what you can do with it after unlocking. (Subject to changes, correction, better reports, etc.):
Tracfone will only unlock Tracfone-branded phones. (Including Simple Moble Total, etc. if you have customer service re-brand them to Tracfone at initial activation). They will not unlock your BYOD phone, regardless of the circumstances.) [EDIT TO CLARIFY: they will not unlock a phone using a BYOD SIM, regardless of circumstances, either-- so a Tracfone-branded devices running on a BYOD SIM cannot be unlocked..]
Time period: 12 months: The phone has to be active with it's registered Tracfone IMEI/MEID & associated SIM card for the 12 months. Tracfone links the 2 together, and as far as Tracfone is concerned, a particular phone is 'active' on the network as long as it's issued SIM card is active, whether or not it's still in the same device. (By anecdotal reports from others.)
Paid Service for those 12 months: If you already have accumulated service time before you start using a phone you hope to unlock, the current 'general wisdom' is it does not count towards unlocking that phone-- it would have counted for the phone that was active when you added the service time. There have been varying reports on whether or not 'bundled' airtime that comes with a phone counts towards unlocking: in my case, it definitely did. I've seen other reports that worked the same, and some credible reports that the phone did not qualify for unlocking with only the bundled airtime applied. If I was rejected under those circumstances, I'd file FCC and Better Business Bureau complaints. (Since Tracfone is under a settlement with the FCC regarding not honoring their commitments to unlock customer phones, I think Tracfone would adjust quickly when the FCC forwards the complaint to them.)
You do have to request the unlock-- it won't happen automatically. You can do it online or by phone, details here:
https://www.tfwunlockpolicy.com/wps/portal/home
I understand that the exact process for unlocking may vary by phone manufacturer: in my instance, the approval & directions for entering codes to unlock the phone came almost immediately. I believe Tracfone iPhones are unlocked through the Apple servers after being submitted by Tracfone.
Caveats: I've seen several reports on Tracfone Verizon-based phones that have been unlocked. It appears there might be a catch in that the IMEIs of Tracfone verizon network devices are not included in the Verizon 'whitelist' database. This likely means that you won't be able to use an unlocked Tracfone to activate a new Verizon-network account, even on an MVNO, but you can probably SIM-swap from an already active device on another MVNO into the unlocked Tracfone.
I am of the opinion that the best candidates for unlocking on Tracfone are bundled phones that are GSM compatible-- at least the GSM part is fully unlocked. Tracfone models ending in DL are multi-carrier (Verizon, AT&T, T-Mobile), and would be great candidates. (Most of the current Moto and Alcatel models are multi-carrier DL versions, as are some LG devices.)
Models ending in BL are AT&T/T-mobile compatible, so they would also be good candidates, but these are not common, especially with bundled airtime.
Models ending in VL are Verizon-network only, including many of the LG Tracfones. These would be the worst choice as unlocking candidates, unless you are comfortable with SIM-swapping as a route for later use, or can confirm that the device has the frequency bands necessary to support use on AT&T or T-Mobile. (Info about frequency band capabilities can be difficult to source on Tracfone devices, and they are often custom variants of manufacturer models:.)
KentE Thanks for this excellent write up! Since Tracfone won’t unlock one of their phones on a BYOD sim, does that mean my Total Wireless branded iPhone would work on Tracfone Verizon/TMo/Att if it has the bands? Even though it might never be unlockable?
I have zero experience with iPhones, so I have to go by my experience with Androids, and simply extrapolate to iPhones.... It's possible that there could be roadblocks I'm not aware of with iPhones.
Yes, I believe it should, although it might take a conversation with Tracfone if you want it to be on Tracfone's Verizon network.
(My assumption is that you have any of the later model iPhones that would have been all-carrier models if they'd been sourced from outside of the Tracfone group.)
As a general rule, phones from any of the Tracfone family can be used with any of the brands. Activating it on AT&T or T-Mobile is the most straight forward, because Tracfone doesn't require the IMEI to activate a BYOD GSM SIM: you register, and activate, the SIM: and you can use it in a a true BYOD device, or a Tracfone-family device.
Using it on Tracfone Verizon is a little different.
The first issue is that anywhere on the Verizon network, you have to register the IMEI along with the SIM.
Tracfone does not officially allow the use of a BYOD SIM in a Tracfone-family-branded device: It's supposed to have to use a Tracfone-specific SIM (like the one that came with your Total Wireless iPhone). On the GSM networks, you can skate through via a BYOD SIM, but not on Verizon.
I've read, but have no personal experience, that the Tracfone group also 'locks' Verizon-network phones to the specific Tracfone subsidiary at initial activation. (In your case, to Total Wireless .) Apparently that subsidiary-specific lock can be changed by Customer Service, by re-SKUing the device.
The existence of 2 parallel SIM lines in the Tracfone family just adds another stage of complication, but it's not insurmountable. In some instances, it gives you 2 possible routes towards activation.
Thanks KentE, really appreciate the vast knowledge you and so many others freely share on this forum. For giggles, I went to Target and got a BYOD Tracfone sim kit. The Total Wireless IPhone is a 7 plus model. Wanting to avoid the whole IMEI thing, I inserted the AT&T Tracfone sim and it connected with the Tracfone network straight away so you are 100% correct (as usual). The whole reason behind my original question was Total wireless has a higher monthly cost than Tracfone does and now I can gift the phone to a friend who is having a hard time making ends meet these days. Thanks again for the guidance!
Chosen, I'm glad the early test looks good. Very nice of you to think about helping your friend!
Honestly, I only skim over a bunch of the discussions about iPhones on the Tracfone family, since I've never had to deal with one. My crude understanding is that limitations are under control of Apple's Activation Policy, and what particular arrangements Tracfone might have been able to work out with Apple as a special accommodation. . I think in some ways, the Tracfone/iPhone limitations are less restrictive than Android limitations, since the Android limitations seem to be entirely at Tracfone's discretion for branded devices.
In general, Apple controls the APNs on iPhones rather than the carriers. Typically, special accommodations amount to the carrier or MVNO reaching an agreement with Apple to sell some number of iPhones. This is why some providers don't offer, visual voicemail, WiFi Calling or VoLTE as examples on iPhones. Of course, I have no idea what specific arrangements exist between TracFone (or any other provider) and Apple.
I don't think this part of Tracfone's policy applies anymore, although I technically didn't have a BYOD SIM, just a BYOD TF phone.
In September, I did one of those HSN deals to get a Tracfone locked TCL flip phone bundled with 1 year of service for my younger daughter. I had my daughter use that phone for 2 months and then asked Tracfone to unlock it. It took about 3 days for them to process the request but ultimately, everything worked out.
As soon as the flip phone was unlocked, I swapped the TF SIM for an Xfinity SIM and then put the TF SIM into a TF locked LG Journey. The service worked fine. After that, I shut that phone down and it has been sitting in my office for 2 months, with it only being used one time right after Thanksgiving to make 1 call.
Today, I chatted with TF to ask them to get the unlock codes for the Journey. They processed it immediately!
I have another TF-locked android phone but it's one of those that don't have VOLTE, just data access to LTE. That phone is in New York, but I'll be able to retrieve it next weekend. I'll be very curious to find out if I can unlock that phone anyway so that it can be used overseas.
I'll also start hunting around on eBay for a cheap iPhone 8 or XR locked to TF :slight_smile:
I believe that Tracfone's unlocking policy changed when Verizon took them over. At least on the
Verizon based services they offer.
It really doesn't work like that. You got lucky with the journey. I would imagine something else was at play. I doubt it will work again but feel free to try and do let us know...
OK so today is Day 1 of "reactivated" service on a Tracfone Moto E6 I bought for cheap on eBay. The phone displays correctly in my account. I did buy an iPhone SE 2nd gen but that one showed as an "unknown device" in my account. I think the SE may have been from Walmart Straight Talk. I'm still within the return period on the SE, and the phone is actually legitimately not as described, so I'll be able to return that one for free.
Experiment on unlocking the Moto E6 didn't work. I was told by the Tracfone CS rep that in order to have the phone unlocked, I had to have it on their service for a full year. At the time I asked, I had only had it on Tracfone for 10 weeks. I pleaded with them that since I had newly activated in February, the 60-day policy should apply. The rep said he had to abide by what the system was telling him, which was a year.
I guess the E6 was first activated by the previous owner at a time when Tracfone's 1-year unlock policy was still in effect.
So, after the lack of success in unlocking the Moto E6, I put the Tracfone SIM into a locked LG Premier Pro for 60 days that I realized was in my pile of junk phones. (The phone is in decent working condition but has a cracked screen, and will be used eventually for a Visible swap.) It successfully unlocked. Perhaps Tracfone's unlocking algorithm is more lenient on LG branded phones.
The full year for unlock was before Verizon bought the Tracfone brand. They now require 60 days like regular Verizon.
Did some more testing on Tracfone's unlock policy with a completely new phone/plan. Here's what happened.
  1. Bought a Tracfone locked Galaxy A13 bundled with annual 1500/1500/1500 plan via www.hsn.com around October 20. There was a major sale.
  2. Activated the A13 around Oct 25, powered the phone down, and put it away for a month in my office.
  3. A month later, I turned the phone on to send a couple of texts. Then I turned it off and put it away again.
  4. On November 27, after I got back from Thanksgiving travels, I contacted Tracfone to request an unlock of the A13. I met the requirements and they processed the unlock and sent me the codes via email. I then used the codes to unlock the A13, which then got promptly listed on craigslist. I've already gotten back the money I paid up front, and more.
  5. I pulled the Tracfone SIM out of the A13 and put it into a Tracfone locked Alcatel Flip2. After testing a couple of calls successfully, I powered it down and put the phone away.
  6. I powered on the phone after New Years to make another call, and then put the phone away again.
  7. On January 28, I contacted Tracfone to request an unlock of the Flip2. They processed it and I got an email with the codes.
  8. I immediately executed the unlock on the Flip2. I still have the phone but it is currently SIM-less.
  9. The SIM was then swapped into a Tracfone locked Alcatel A3 (A509DL). I had gotten this one for a really cheap price via eBay to run this test.
  10. In early March, I power up the phone to make an obligatory call to ensure that Tracfone doesn't suspend and deactivate the line. I keep doing this because my last annual plan got deactivated due to extended non-use.
  11. Yesterday, I contacted Tracfone to request an unlock on the A3. They processed it but I didn't get the email. I contacted them again this afternoon and the email finally came through.
  12. I executed the unlock on the A3. I've only tested it on main Verizon so far. After more thorough testing on the T-Mobile network I'll probably sell it on CL. (BTW, it runs Android 11 and has a removable battery although its texture is cheap and the processing power is underwhelming.)
  13. The SIM is being put into a Tracfone locked Blu View 4 that I found over the holidays.
  14. I'm assuming that the View 4 will get unlocked when I contact Tracfone in early July.
  15. After that, I'm thinking of putting the SIM into a Tracfone/StraightTalk locked iPhone 6 with a damaged screen. I'm expecting Tracfone to disapprove an unlock request on this one, because it was activated prior to Verizon's acquisition of Tracfone being finalized.
  16. After verifying unlock failure on the iPhone 6, I'll find a way to use my minutes, probably by porting in my main number and swapping the SIM into whatever iPhone is my daily use phone at that time, probably an SE3 with Tracfone for minutes/text and Visible for data.
What I find amazing in all this bingyee is that you just kept moving the SIM card and never had an issue, not that you really used the phones.
Conventional wisdom would dictate using a new $1 TF BYOD SIM kit each time you changed phones.
I have some theories on why I didn't get dinged:
  1. that rule doesn't apply to phones that were sold by (and locked to) Tracfone
  2. that rule is triggered by a certain amount of usage, which I didn't exceed
  3. it's an obsolete rule that's gone away, perhaps due to the Verizon acquisition
Wish we knew for sure if #3 is true.
I have a small amount of anecdotal past experience that I thought meant the opposite of #3 (that leading up to and after the Verizon acquisition, they had cracked down harder on matching the SIM to the activated IMEI and the Verizon Blessed Device List), but from what I recall about what happened, it could match #2 as well.
I have figured it out. It's sort of related to #1. There doesn't seem to be a problem with SIM swapping as long as the phone is originally sold by TracFone OR if the IMEI is in TracFone's database. When you swap SIMs and you want to use an unlocked phone not sold by TracFone, they enter in the new IMEI into their system.
I had the misfortune of SIM swapping into an iPhone SE 2nd gen that was sold by Apple. It initially worked and then I suddenly lost all my airtime within a few hours. The account was able to be restored by activating a new SIM associated with a different phone. I gave them an IMEI of a 1st gen iPhone SE that I think was sold by AT&T. That's when the rep added in that IMEI into their system.
Unfortunately, I still didn't get my airtime back. Doesn't matter - I was just using the line to unlock Tracfone sold phones, and at this point I've run out of useful ones at this point. I still have an iPhone 6, but apparently that one's data won't work, probably due to Tracfone's new carrier settings no longer compatible with IOS 11.
I am pretty confident that there are members here that follow and sometimes post on SD and/or Howard Forums and have been following along or experiencing first hand the Straight Talk Moto G power 5g 2024 not unlocking fiasco.
I'm not a member/poster at either but wanted to mention something that TF/ST asked me to do during a callback responding to my FCC complaint.
Something that if it was mentioned I missed it and I read through them pretty carefully.
Feel free to post elsewhere for wider feedback or possible explanation from a knowledgeable member of another forum and to confirm my results or maybe someone gets lucky and it works to unlock their phone.
Previously mentioned was the known code to prompt for manually entering unlocking code(s) #TFUNLOCK# (#83865625#)
but
On this phone that is supposed to "automatically" unlock that entry on the dial pad just returns a message that the device is SIM locked.
Today TF CS person had me enter something slightly different that I haven't seen mentioned in re to this phone unlocking.
##83865625# & then tried ##83865625##.
Neither worked to unlock my phone but did prompt the phone to briefly display "USSD Code running" and then returned "TracFone Message
connection problem or invalid MMI code"
along with an "ok" button.
Curious what USSD code and MMI code acronyms mean if something interesting particular to this situation beyond the generic
https://en.m.wikipedia(dot)org/wiki/Unstructured_Supplementary_Service_Data
https://www.technobezz(dot)com/fix-connection-problem-invalid-mmi-code/
